Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more
Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
ATI Radeon HD 4850 512MB
XFX GeForce 9800 GT 512MB XXX Edition
ATI Radeon HD 4830 512MB
Nvidia GeForce 9800 GT 512MB
Nvidia GeForce 9600 GT 512MB
Nvidia GeForce 9600 GSO 384MB
ATI Radeon HD 4670 512MB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Nvidia Geforce 9800 GT 512MB
Nvidia Geforce 9600 GT 512MB
Nvidia Geforce 9600 GSO 384MB
Frames Per Second
The advantages of the XFX GeForce 9800 GT 512MB XXX Edition overclock are pretty obvious here, with performance that tends to be three or four (and at 1,280 x 1,024, 4xAA almost six) frames per second faster than the stock 9800 GT. With the enhanced clocks the XFX 9800 GT is even able to push the Radeon HD 4850 off the top spot in a number of tests, most notably those where 4xAA is enabled.
